1998 GMC Jimmy Fully Loaded - Might Purchase
Old Jul 21, 2009 | 11:43 AM
dew88's Avatar
dew88 is an unknown quantity at this point
Default 1998 GMC Jimmy Fully Loaded - Might Purchase
Hey guys,
As I am sure most of you know I have a 1996 chevrolet blazer 4x4 that I am almost done with. Well I found a 1998 GMC Jimmy Fully Loaded, AC, Sunroof, Etc.
What are some immediate off the top off your head things I should look for when I check it out..
Obviously..
Oil Leaks
Water Leaks
Rust (Im In Florida Not Much Rust Here)
Knocks
Pings
Ticks
Anything Else? Thanks
Old Jul 21, 2009 | 02:51 PM
paxlineman's Avatar
paxlineman is on a distinguished road
check all the steering components my brother had one and ended up having to rebuild alot.
Old Jul 21, 2009 | 04:56 PM
The_Beast's Avatar
The_Beast is on a distinguished road
tire tread to see if there's alignment problems
Old Jul 21, 2009 | 09:01 PM
bandidolenny's Avatar
Make sure the tranny fluid is clean and things looked liked they have been serviced on a regular basis.
When you turn on the key make sure all the warning lights (check engine, air bag, abs, etc) illuminate and then go away.
Old Jul 22, 2009 | 12:19 AM
4x4blazerguy's Avatar
The Engine. The 4.3s can be a real piston slapping engine. Drive it & run up the RPMs under load see if you hear any knocking noises. Also any slight lifter or rocker noises. After owning this 97 we have with its piston slapping rocker knocking engine. I'm not sure I will buy another even as much as I like it. Ours is on its second engine in 116,000 miles.
londonmazda
Oct 19, 2010 02:15 AM
danmcph
Mar 29, 2010 09:56 AM
garry2000blazer
Nov 16, 2007 07:05 PM
epitaphoftwilight
Apr 5, 2007 03:18 AM
