1999 blazer 2wd engine in a 4wd???
Old Mar 28, 2013 | 03:04 PM
nathanb198's Avatar
nathanb198 is on a distinguished road
Default 1999 blazer 2wd engine in a 4wd???
i have a 1999 blazer, broke a rod in original motor, i pulled it out and scrapped it. i purchased a 2wd motor from the same year. replaced oil pan..... not sure what if anything else there is to change, replace. any info would be greatly appreciated. i know im a noob, but i did my research before i asked..
Old Mar 28, 2013 | 06:16 PM
coolasice's Avatar
coolasice will become famous soon enough
maybe exhaust mainfolds but not 100% sure... do you still have the old motor? look at them to see if anything else is different.
Old Mar 28, 2013 | 09:49 PM
kcb37's Avatar
kcb37 is on a distinguished road
In theory the engine will drop right in, to include a 4.3 out of a fullsize pickup or Astrovan.
But sometimes their are little things like the oil pan etc...
Like said if it looks the same it is.
Old Mar 29, 2013 | 08:02 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
Oil pans are different, on the 4x4's they relocate the oil filter for a reason. It's a b%@&h to get to. I would swap the remote oil filter system over. Other than that its all the same if you have the same year
Old Mar 29, 2013 | 10:08 AM
nathanb198's Avatar
ok, i have swapped the remote oil filter assembly, replaced the oil pan, but somethings not right.. i have the front diff dropped down and its like the enigne is just too tall... if i had the engine bolted down on the mm's again the front diff would not come back up in alignment with its bolt holes
Old Mar 29, 2013 | 10:09 AM
nathanb198's Avatar
i hope i wasn't lied to about the year of the engine.... is there any way to tell by numbers or marks stamped on it??? EDIT: no i do not have the old motor, if the exh mans are different ill have to buy new ones... :/ i do know that is the same style motor, 4.3l v6 vortec, but its like its too tall, i have thought about taking it from a 4wd to a 2wd but not sure how, also don't really wanna f*ck with the front diff. plus i like 4wd. on a side note i have thought about my styer m95 with German armor piercing rounds(on several occasions)
Old Mar 29, 2013 | 11:09 AM
nathanb198's Avatar
Cool
according to the local chevy parts department, 2wd and 4wd exh mans are the same, also lookie what i done.
Attached Thumbnails 1999 blazer 2wd engine in a 4wd???-img_1320_zps8cc2fa91.jpg
Old Mar 29, 2013 | 11:14 AM
rexmburns's Avatar
Super Moderator
post a picture of the top of the motor so we can see it. Alot of times the year/years can be identified by just seeing the motor and knowing the differences as the motor evolved over the years.
Old Mar 29, 2013 | 11:33 AM
nathanb198's Avatar
heres 4 pictures, i traded the intake manifold and injectors because i didnt like the look of the old one. other than that its all the same
Attached Thumbnails 1999 blazer 2wd engine in a 4wd???-img_1326_zps0b1addfd.jpg   1999 blazer 2wd engine in a 4wd???-img_1325_zpsd1280830.jpg   1999 blazer 2wd engine in a 4wd???-img_1324_zps77e68d76.jpg   1999 blazer 2wd engine in a 4wd???-img_1323_zpsebbec68e.jpg
Old Mar 29, 2013 | 11:35 AM
nathanb198's Avatar
and yes that is a blow torch.... cross threaded a bell housing bolt in the block.... trying to get it out with out helicoiling
