front right wheel making noises
Old May 24, 2009 | 03:54 PM
xxdatricandudexx's Avatar
xxdatricandudexx is an unknown quantity at this point
Default front right wheel making noises
Hi i have a 1998 blazer lt 4wd and the front right wheel sounds like its grinding it starts at about 15 mph and gets a lil quiter but dosent stop all the way at about 60 65 mph can anyone help me with this problem. i have replaced the wheel hub bearing bout 6 months ago can that be bad again???
Old May 24, 2009 | 04:17 PM
Does the grinding go away when you turn left or right? If so, which direction causes it to go away?
Old May 24, 2009 | 08:28 PM
no stays the same even when i turn left or right... Im fustrated now when i get in the truck and put the truck in drive it makes a grind noise like gears hitting?? lights on the dash flicker for a second. truck runs fine, shifts perfect 4wd is perfect 4 lo is perfect. I just dont know what it could be.
Old May 24, 2009 | 09:31 PM
Hiddenfarce's Avatar
Hiddenfarce is an unknown quantity at this point
I've had the same issue. I chalked it to really cheap crappy ceramic pads. My noise varies depending on temp, and when I turn. The left front creates crazy dust unlike the others. It also may be a stuck caliper.
ComputerNerdBD
45
May 20, 2012 10:36 AM
ComputerNerdBD
Feb 29, 2012 08:09 PM
BLK85
Jun 7, 2007 01:37 PM
BobTheBlazer
Feb 18, 2007 04:41 AM
2001blazer
Mar 29, 2006 01:51 AM
