1999 Blazer instrument cluster problem?
Old Apr 20, 2011 | 12:05 AM
n9ktw's Avatar
n9ktw is on a distinguished road
Default 1999 Blazer instrument cluster problem?
I have a 1999 Blazer which I have owned since 2008. It has started having a battery run down problem.
I located the problem to fuse #19 which is the radio and the instrument cluster. I removed and disconnected the radio and still saw almost a 1 amp draw on the circuit. Disconnected the instrument panel connector (the one at the top center), and lo and behold, no more load on the circuit. Of course this also made all the gauges not work.
I do have a 2-way radio that is in the car (wired directly to the battery and not connected to ANY other wiring )which has a case of alternator whine. Could a bad alternator be the source of my phantom draw? Or am I looking at buying a new cluster? Everything else works fine aside from the almost 1 amp draw.
I do have a strong electronic background so removing and testing things is not a problem
Thank you for any help.
Howard
Old Apr 20, 2011 | 06:58 AM
*Thread Closed - Double Post* - Please do not post the same thread in multiple forum sections as this is prohibited by the rules of the forum. To avoid further violations, please familiarize yourself with the rules. Thanks!
muddyboots
Nov 18, 2013 02:59 PM
car5car
Jul 14, 2012 12:07 PM
kgpace
Jul 16, 2009 12:13 PM
Hot Rod
May 13, 2008 01:43 PM
Russ57
May 14, 2007 01:43 AM
