1999 Blazer ZR2. The AC is not working. Where are the most common leaks?
Old Sep 16, 2018 | 09:42 AM
  #21
GeorgeLG's Avatar
Automotive AC fittings for 134a are unique and not the same as residential HVAC. Threaded fittings are Acme (1/2 or 3/8” I believe) which are different thread pitch than std 1/4” flare threads for residential HVAC and usually attach to Schraeder ports. The other fitting style is what you have. Those are called quick connect, safety lock, easy snap, service couplers, or automatic service couplers. Those are push and click which either open the ball valve on the port automatically or you have to screw a dial on the fitting to push the ball valve open. The hi and low side are different sizes. I believe that the sizes are 14 x 16mm and 14 x 13mm respectively if I remember correctly.
George
Old Sep 16, 2018 | 10:12 AM
  #22
awesomeamerican1's Avatar
awesomeamerican1 is on a distinguished road
When you have the ac system apart your best bet is to replace every single o-ring while your in there. You can usually find a whole o-ring kit for a couple bucks. You’ll also want to clean the whole system out with some brake clean or carb clean because usually a leak from the compressor means there are metal shavings all through the lines. I also put in some uv die into the system so I can detect future leaks with a black light flashlight. Just my .02 from experience fixing my system.
Old Sep 16, 2018 | 11:04 AM
  #23
GeorgeLG's Avatar
O rings, the accumulator/dryer and all schrader cores. Remove the seal caps, install the accumulator and start the evacuation process quickly to maintain the desiccant capacity.
George
Old Sep 17, 2018 | 06:50 PM
  #24
George
Just a quick add to this since you mentioned it georgelg and correct me if I am wrong. When we did my AC system, I believe we added a vacuum to the system and held it for 30-45 minutes before going on to add any oil or freon. Gets it nice dry and clean again. Also helps check for leaks one last time.
Old Sep 17, 2018 | 10:39 PM
  #25
GeorgeLG's Avatar
You check for leaks with a nitrogen charge, then you evacuate to between 300-500 microns, blank off the pump and make sure that the vacuum holds. If not then there is still moisture in the system. Further analysis is if you rise to and hold around 1300 microns then it's moisture but if it rises steadily toward ambient the it is a leak. The time for vacuum depends on the system condition, pump and hoses.
George
jrm000kc
Dec 22, 2017 11:29 PM
redneck44244
Jun 19, 2012 12:03 AM
blazeraz
Apr 30, 2012 02:25 AM
carterx
May 26, 2009 06:58 PM
turboxb9s
Jun 20, 2006 09:08 PM
