1999 wont run
Old Sep 7, 2010 | 03:56 PM
jerry osaer's Avatar
jerry osaer is on a distinguished road
Default 1999 wont run
4.3 wont start when it dos it runs real bad check codes p1345 checked timing chain in time checked cam in time dist. lines up on the 6 changed crank sensor cam sensor coil... coil wire what can i do next could gear be worn that bad... but pointer lines up on 6 on dist.with balancer on mark any body had this prob let me know thanks
Old Sep 7, 2010 | 04:02 PM
How much rotational play is there in the distributor. You could pull the distributor and check the gear.
Have you done any other preventative/regular maintenance? There could be more than one problem at hand here.
Old Sep 8, 2010 | 08:03 PM
full tune wires and plugs cap im going to pull dist and try that... could cat be pluged 150000 miles
m3dragon
Feb 24, 2015 10:04 AM
chevychevelle
Jan 19, 2009 07:47 AM
cle_chris1
Mar 12, 2008 07:45 PM
97blz4x4
Oct 14, 2007 07:45 PM
justblazin
Nov 19, 2006 12:10 AM
