#2 misfire on rebuilt 4.3
Old Jul 11, 2009 | 05:51 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Your misfire is not a timing issue,it is from the low compression on cylinder 2.. it is possible you broke a ring installing the piston or didn't install the rings properly.
Old Jul 11, 2009 | 06:09 PM
3hondacrx's Avatar
3hondacrx is an unknown quantity at this point
I didnt rebuild the motor, I just did the installation and everything else and Yes as a matter of fact it is after market. So I will put the old one cap/rotor on and see what happens. get back to ya.
Old Jul 11, 2009 | 07:42 PM
3hondacrx's Avatar
Ok ive changed out the cap and I cleared the code. Drove it till light came on and checked it... Now its thrown the random multi misfire code only .... Timing???
Old Jul 11, 2009 | 07:54 PM
reelbroke2's Avatar
sounds to me like the original old cap isn't good
Old Jul 11, 2009 | 08:32 PM
3hondacrx's Avatar
So then the timing??? does the 6 line up to the rotor exatcly cuz it aint?
Old Jul 11, 2009 | 08:34 PM
reelbroke2's Avatar
as long as you are within a couple of degrees its ok..It does not line up exactly
check this out for more info on timing..https://blazerforum.com/forum/tech-articles-diy-29/edi-engine-timing-24373/
Old Jul 11, 2009 | 09:29 PM
3hondacrx's Avatar
Default Omg!!!
Ok I took the valve cover off finally... Its a lazy thing I need to kick... And I found the most crazy thing I have ever seen. The rockers where just layin side ways the washers and nut wher just sittin on the head and I noticed there where no ***** freakin push rods! Dude!!! Where did they go??? How??? What??? OMG!! I cant believe I drove this truck 80 miles an hour down the highway like this. Chevys!! There tough even when not built all the way...
Old Jul 11, 2009 | 09:33 PM
Push rods are likely down in the lifter valley. Time to pull the intake!
Old Jul 11, 2009 | 09:45 PM
reelbroke2's Avatar
That will explain your low compression and misfire! you must not have had the push rod on the lifter correctly or the nut wasn't torqued.
Old Jul 12, 2009 | 12:37 AM
3hondacrx's Avatar
Ive pulled the intake found the push rods still in good shape I will put it together in the mornin after I get RTV sealent and hope all is well...
