2000 2dr 2WD - New Break Pads stuck
Old Mar 26, 2007 | 07:08 PM
tnblazer's Avatar
tnblazer is an unknown quantity at this point
Default 2000 2dr 2WD - New Break Pads stuck
Ok, so, I did the "economic" thing and replaced my rear disk break pads this weekend, after a4 hour ordeal of needing to replace one of the Caliper Housing Bolts as it had seazed inside it's shaft. So, got that accomplished, placed the Duralast Gold break pads from AutoZone on there and went driving. It stops so much better now, but too good, come to find out, the pads are always rubbing now on the disk, they don't let off!
Is there any sort of adjustment on these things? I couldn't find anything and the calipers seemed to seat just fine, but they don't come off and it is killing my fuel mileage, any ideas?
Old Mar 26, 2007 | 07:29 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: 2000 2dr 2WD - New Break Pads stuck
First, the the parking brake ( Not BREAK) linkage, if its contacting, loosen it. If it ain't the park brake, Take a hammer and tap the brake pads back toward the caliper, if its stuck, it should come loose. If that is not the case, the caliper could be sticking, use channelock pliers to compress the piston, if it doesn't move at all, it is stuck or has a bit of residual pressure. If it has pressure on it, replace master cylinder. If it is stuck check theinside of thecaliper.
edited to be friendly - Hillbilly
kontrix
Lowering Tech
Nov 8, 2012 01:12 PM
blazerguy22
Aug 8, 2011 02:14 PM
ExplicitYourSelf
Oct 27, 2009 03:54 PM
SecGenBlzr
Oct 26, 2009 09:43 PM
MajorMajor
Feb 9, 2009 10:42 AM
