2000 Bløazer LS problems with the immobilizer
Old Aug 28, 2016 | 08:35 AM
TheSaint's Avatar
TheSaint will become famous soon enough
Default 2000 Bløazer LS problems with the immobilizer
Every time i stop the engine on my 2000 Blazer LS i have to lock and unlock the car using the keyless remote for the car to start.
If i just turn off the engine and try to start the car it will not start because the immobilizer prevents the fuel pump from getting power i guess
Any members here know if i recode the keyless remote will that help/fix this problem?
Like code a new keyless remote to the car i mean
Old Aug 29, 2016 | 06:42 AM
LannyL81's Avatar
Is this an aftermarket or factory alarm key fob/remote?
Old Sep 1, 2016 | 01:36 PM
DaveHearne's Avatar
DaveHearne is on a distinguished road
If this is a European-spec Blazer it is quite normal to have to use the fob to enable the vehicle to be started. When you unlock the vehicle with the fob, you have 2 minutes to start it before the immobilizer re-arms itself. When you turn the engine off you have 20 seconds to restart it before the immobilizer re-arms itself. It is a pain I know but is something you just have to get used to i'm afraid. Why on earth GM went down this route with the export models I will never know but that's just the way they are. The European-spec Cadillac Seville is the same. If you use just the key to unlock the vehicle it will start for a couple of seconds & then stop.
Old Sep 1, 2016 | 06:02 PM
TheSaint's Avatar
The car is a European-spec Blazer. As far as i know it have the factory alarm key fob/remote
I have checked it out a little more and the car behaves like what DaveHearne
describes so then it is supposed to be like this.
I am alsready used to the car behaving like this so it is no major problem
Thanks for your help
jello219
Sep 3, 2019 05:19 PM
01Blaze218
Oct 13, 2011 10:05 AM
Frustrated
Jun 11, 2010 07:53 PM
upblazer95
Apr 4, 2009 08:27 PM
big440
Nov 9, 2006 09:40 PM
