Keyless remote for a European model 2000 Blazer LS
Old Aug 27, 2016 | 03:30 PM
TheSaint's Avatar
TheSaint will become famous soon enough
Default Keyless remote for a European model 2000 Blazer LS
Hi
I need a spare jeyless entry romote for my 2000 Blazer LS
My Blazer is made for the European marked and i also think the car is made in Graz, Austria
The part number for the keyless entry temote on my car is GM/UTA 15732810
It looks like part numer: 15732805 is the most common used in the US ore most common on ebay so any here knows if i can use the one from ebay?
Old Aug 27, 2016 | 04:36 PM
richphotos's Avatar
That should work for you.
Just make sure the one you get one that has the same FCC number or, if I am not mistaken will not work with your module.
Old Aug 27, 2016 | 05:20 PM
TheSaint's Avatar
Is the FCC number the same number as what it says on my keyless remote?
I have not seen any keyless remote with the number GM/UTA 15732810 which is the number on the keyless remote for my car when looking for a keyless remote on ebay
I am sure that i can buy one with the same number at a parts shop
Old Aug 31, 2016 | 10:12 AM
DaveHearne's Avatar
DaveHearne is on a distinguished road
I believe that the European remotes are discontinued, at least the UK-spec ones are. I have a friend who got around this by purchasing a keyless entry receiver unit from a Blazer in a US junkyard along with 2 matching remotes & installing it into his UK spec Blazer. However, to program them once everthing is installed requires the 5 digit immobilizer code which every European spec Blazer comes with to do so. This code was supplied on a red card with every new vehicle, if you don't have that then it can be accessed with a Tech 2. Hope this helps.
By the way - all export Blazers were built at the Linden, New Jersey plant.
Old Sep 1, 2016 | 06:43 PM
TheSaint's Avatar
I have found a place online that sells the keyless remote part number: GM/UTA 15732810
www.remote-superstore.com sells this keyøess remote with the correct part number
420Blazin4X4
Sep 9, 2012 11:16 PM
ComputerNerdBD
Oct 16, 2011 06:10 PM
saulyss
Dec 21, 2010 09:00 AM
Mczuk
Mar 3, 2010 03:27 AM
Marcin
Shows & Clubs
Nov 27, 2006 07:23 PM
