2000 Blazer 2wd-Access fuel pump thru cabin
I have 2000 Blazer 2wd and need to replace fuel pump.
I would like to do it by cutting a hole in the floor.
Can somebody provide a link to a write up on how to to it for this
particular model?
thanks
particular model?
thanks
I wouldn't suggest doing that. Just drop the tank, it isn't as hard as you would think. I've changed pumps on 3 blazers now.
I've seen a thread somewhere about this. Not sure if it was on here. The guy cut a 1'x1' square, and put hinges on it. When the carpet is down, you couldn't tell.
But really, it's a lot easier to just drop the tank. Pump all the gas out, first. That is, if the pump works at all.
And if you go back in with a Delco or Delphi, you shouldn't be dropping the tank again for another 100k or so miles.
Verwah
14
04-10-2018 07:56 AM
dubaholic2
06-19-2011 09:06 PM
jcortes63
11-03-2008 11:10 PM
