2000 Blazer 4.3 LS 4x4 drivers side front end noise?
Old Feb 10, 2012 | 01:30 AM
Petro821's Avatar
Petro821 is on a distinguished road
Default 2000 Blazer 4.3 LS 4x4 drivers side front end noise?
I just bought my son a 2000 blazer LS 2dr with 66000 miles on it nice truck runs good. The dealer put new ball joints and it looks like a few new steering arms in. The problem I'm having is that at low speeds 20-40 mph it sounds like their is something loose or their is play in a bushing or shock or something?? Noise seems toe from the tire area. I jumped under their and looked everything looks ok no visible wear?? Dealer tells me everything is tight but it isn't ??? Any ideas where to start my search??? Thanks for any help!
Old Feb 10, 2012 | 06:23 AM
*Moving to 2nd Gen Tech* - The New Member section is for new member introductions. Please read the forum section description & choose the section that is the best match to the nature of the question you are inquiring about.
What does the noise sound like? Does it change in any way when you steer to the right or left? If so, list the change in sound for each direction.
I replaced the shocks in my old '00 Bravada and had a clunking noise afterwords. The problem there was the upper shock mount. The metal sleeve in the new aftermarket shock (Monroe Reflex) was narrower than the mount and torquing the bolt to spec didn't pull the mount in tight to the sleeve. Tightening the bolt up beyond spec solved that problem.
I also had a hood hinge pin rattle that drove me nuts. GM has a service bulletin on this and conical washers that can be purchased that are supposed to fix that issue. Link from the Tech Article (DIY) Index: Hood Hinge Rattle - TSB 01-08-63-001B You can diagnose this by putting a wadded up rag up on top of the firewall near the hinge on the side you think the noise is coming from. Wad it up just enough to put some additional tension in the hinge, but not enough to bend the hood. If the noise goes away, go get some of the conical washers from the dealer.
Old Feb 10, 2012 | 06:26 AM
pettyfog's Avatar
Do you have jackstands and a jack? Remove wheel and jack the lower arm up {close to ball joint as possible} till it starts to lift truck.
- works for everything but sway bar links. test those for slop, wheels on ground or disconnect one end and check slop.
added: And check to see if you can easily move the brake pads around. Missing clips can cause pad rattle which is truly annoying.
Otherwise take it to a good independent shop with seasoned mech who does suspension work. He can probably tell what it is by sound.
Old Mar 15, 2012 | 07:51 AM
dano440's Avatar
dano440 is on a distinguished road
I had the same rattle from the shocks I just replaced 5 months ago and last night I got them tightened up and made a huge difference, but now I can hear the driver's side hood hing.
upmaine
Jul 9, 2012 12:31 PM
janddcunningham
Jun 2, 2011 10:26 PM
Wexinlo
Apr 6, 2011 11:35 PM
clw97bravada
May 20, 2010 08:52 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
