2000 blazer 4wd 4l60e trans ?
Going to be changing my radiator in the next day or so.
its an automatic 4l60e trans 4wd
how much fluid should i expect to replace and what should i top it off with?
An idea I've used unless you have a big leak-flush it now,then swap out the radiator,and once its all back in place-flush it again! Then use a quality coolant to remedy future issues with Dexcool! Just a thought. But 2 gallons will be more than enough to fill your system.
reply
like the other guy said bought to gallons but i wouldnt use dexcool its junk it can gum up and eventually become corrosive. i use prestone its better and had the best luck with it. and its quaified to be used with mix brands. i changed my rad in mine and used prestone
i should have been more specific, was thinking about the trans fluid :-(
I put in a new radiator about a year ago. If my memory serves serves me correctly, I only
had to add about a half quart of transmission fluid to make up for what dripped out from
the cooler lines. Not much. I had a transmission fluid and filter change at 150,000 miles.
I added 4 quarts of Dexron 6 and 1 quart of Lucas. She has been doing fine with this mix.
I have never had a flush so I am thinking I have a mix of Dexron 3, 6 and Lucas in there.
Mark
Mark
Thanks guys, got the job done with you're help!
The quick disconnect fitting on bottom passenger side below the lower hose was a mother to get at and off
dj00140
22
11-04-2015 06:03 AM
Flatearthman
07-11-2012 07:53 PM
an240172
09-07-2009 03:58 AM
95blazer8620
10-19-2007 02:26 PM
