2000 blazer fuel tank bolt
Old Jul 31, 2018 | 07:52 PM
Krow's Avatar
Krow is on a distinguished road
Default 2000 blazer fuel tank bolt
I have a bad fuel pump on a 2000 blazer. Front bolt for the straps came out ok, but the bolt at the rear straps of tank came out only so far and now just spins. Is there any way to get it out or do i just have to cut it? If i cut it can i somehow get a new bolt in?
Old Jul 31, 2018 | 11:15 PM
Rusty Nuts's Avatar
Welcome to the forum. The fuel tank straps are held in with a nut and bolt. A back up wrench on the top nut will let the bolt unscrew.
Old Aug 1, 2018 | 12:43 PM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
If it doesn't back out with a wrench as previously stated...I would cut it. It is a bolt and like a fender nut. They are readily available thru GM or a body supply house or I guess you could nut and bolt it but that may be tough to hold the nut as it spins-never did it that way. Good Luck-Jerry
Old Aug 1, 2018 | 08:32 PM
Krow's Avatar
I will give that a try tomorrow. Thanks guys
burnout350
Lifting Tech
May 22, 2012 01:16 PM
moe_23
Apr 13, 2010 10:58 PM
duvall45
Aug 29, 2009 04:19 PM
Black 1998 Blazer
Dec 15, 2008 08:43 PM
4x4blazin
Tires and Wheels
Dec 14, 2006 10:53 PM
