2000 blazer Ls
2000 blazer Ls
I had to change both rear calipers.After doing so and spending a lot of time bleeding them I now have very little brakes. the pedal goes to the floor and the light stays on.I get some pedal when I pump it up but it losses pressure the first time I use it.(all fittings are tight and I have no leaks)
Make sure the calipers are on the right sides (bleed screws up) and that the new gaskets are on correctly first,I used a vacuum pump on mine (mitey vac) because the lines had drained while I had the cals off and I didn't want to wait for gravity. Once the cals are partially full of fluid,finish with a traditional pedal bleed.
Post #2 in this thread explains the gravity bleed process: https://blazerforum.com/forum/2nd-ge...46/#post559116
jello219
09-03-2019 05:19 PM
01Blaze218
10-13-2011 10:05 AM
JODYM
02-02-2009 07:53 PM
