2000 blazer Ls still runs rough
Old Aug 30, 2012 | 09:33 AM
jim1's Avatar
jim1 is on a distinguished road
Default 2000 blazer Ls still runs rough
After changing the timing cover and chain,and gasket my engine now runs rough.We double checked the marks on the timing gears and chain they are where they are supposed to be. we also replaced the crankshaft sensor,plugs and wires.We timed it to tds#4 like the hayes book said. Is this correct? Also do you set the rotor on the dist. to the number on the top of the dist. or to the pin on the inside of the dist. that lines up with that number.
Old Aug 30, 2012 | 02:21 PM
Dadatone's Avatar
Dadatone is on a distinguished road
Have you tried reading this post?
https://blazerforum.com/forum/tech-a...-timing-24373/
Very helpful for setting your initial timing when you replace or remove the distributor.
Old Aug 31, 2012 | 07:42 AM
jim1's Avatar
how do I read the post
Old Aug 31, 2012 | 12:07 PM
50lb_cat's Avatar
You will also have to do a crankcase relearn since you replaced the sensor.
Old Aug 31, 2012 | 08:44 PM
Dadatone's Avatar
jim1, what I meant by reading the post was to compare what your repair manual says (which has been known to be wrong) with what the write up says you should do in order to time your engine correctly.
I would start reading the post from the very beginning. It will help you set your initial timing correctly. Then, as 50lb_cat said, you'll need do what the very last statement says to do in the write-up. Most shops should be able to do this very simple procedure for you. And, it shouldn't cost that much either.
Old Aug 31, 2012 | 10:08 PM
Rottidog's Avatar
You read it by clicking on the red link
ooseven
64
Feb 1, 2015 12:54 PM
szumkel
Jan 16, 2012 04:32 PM
davtak
Jun 28, 2011 08:47 PM
sword2269
Sep 9, 2009 07:33 PM
c10jm
Aug 12, 2008 05:34 PM
