2000 Blazer LT
Old Sep 11, 2020 | 02:49 PM
Lv_radar's Avatar
Lv_radar is on a distinguished road
Default 2000 Blazer LT
So, short and sweet; Brand new battery, won't start.
when I turn the ignition the thing just keeps cranking with no turn over.
I've tried resetting the passlock to no avail. When the door is closed and no key in, the door chime still rings away. That's the only information I can really give unless someone makes a suggestion.
This is the first time it's ever happened and I'm stuck.
Any suggestions would be nice.
Thank you.
Old Sep 11, 2020 | 02:53 PM
Got fuel getting to the engine?
Old Sep 11, 2020 | 02:54 PM
Lv_radar's Avatar
Well, fule injector spider was on the docket. It was having a position misfire. Could that be it?
Old Sep 11, 2020 | 02:56 PM
Not sure... any codes? Have you done any kind of tests?
Old Sep 11, 2020 | 02:57 PM
Lv_radar's Avatar
Haven't been back to the thing, yet. Left it in a parking lot to get my code reader and do some research.
Old Sep 11, 2020 | 05:36 PM
Listen for the fuel pump to run for a couple of seconds when you turn the key on. If it isn't turning on, kick the bottom of the fuel tank a couple of times and try again. That often works to get you home when a fuel pump is on its last leg.
If the pump does run, pull a plug wire and check for spark.
Old Sep 17, 2020 | 03:24 AM
go chevy's Avatar
I like that, "kick the bottom of the fuel tank"... I love this Forum, I learn a new trick almost every day
Old Sep 17, 2020 | 01:55 PM
LesMyer's Avatar
Yeah, that's pretty definitive for a bad fuel pump if it comes on when you kick the tank. You could also jumper that FP relay if you're not fast enough to kick the tank within 2 sec after turning the key on! Tom is just faster than me!! :-) I guess he means it may come on after kicking the tank and then cycling the key!!
richsa72
Mar 7, 2017 09:41 AM
Kai90
Feb 25, 2016 07:56 PM
zblazerz
Apr 8, 2015 12:22 AM
matt94
Nov 12, 2011 10:26 AM
wings4kites
Jul 10, 2010 07:28 PM
