2000 Blazer LT 4WD engine replacement, ready to start?
Old Feb 24, 2013 | 11:45 AM
aksallday's Avatar
aksallday is an unknown quantity at this point
Exclamation 2000 Blazer LT 4WD engine replacement, ready to start?
how should i go about priming the engine and trans with oil?
how are these motors timed or are they non adjustable?
(im pretty sure i had the motor at TDC before we put plugs in and dropped the motor in, but i dont know if the position of distributer spindle/rotor is correct)
do these suvs have any issues with passlock after replacing the engine with a matching oe engine?
anything im missing when it comes to these suvs and staring after a replacement engine?
heres the story with it, last year i bought a running blazer on a crazy good deal. its a 2000 chevy blazer lt 4wd 4.3auto, 150k, mint body and interior. i knew the engine didnt have long, as it smelled coolant. we got 6 months out of it before it blew the headgasket and locked the engine up when all the coolant dumped into the engine.
i pulled the dead engine and found a certified "running" 4.3 v6 out of a 98-99 S10, with 115k and a year warranty. i stuck it in last weekend, and have everything mechanical and electrical hooked back up now. except i have a mystery plug, its 2 prong female and comes out of the harness between the fuel delivery and throttle body on top of the engine, i think the rubber jacket on it is blue or black
anyone every ditched the clutch fan out for flexalite style electric fans?
Old Feb 25, 2013 | 04:35 PM
lityjohn701's Avatar
lityjohn701 is on a distinguished road
Default Might help a little
Well I'm 15 and I have. 1998 blazer that had a blow motor it's going to be my first car. I got a 98 s10 engine with 90 k miles since the firing order is 165432 we took out the number 1 cylinder spark plug stuck a screw driver in and turn the engine over just like one turn till you can feel the topof the piston. The distributor is fixed so you cannot turn it to time then just line the distruvtor up with number 1 cylinder and you should be set and a little tip is to make sure the oil pump is lined up with the distrubtor!! My dad has a 6 in long 3/8 extension that he grounded down two side of it to fit in the oil pump. Then taped another extension onto that good luck!
Old Mar 7, 2013 | 05:08 PM
Blade_24k's Avatar
Blade_24k is on a distinguished road
i haven't sawpped for the electric fan yet. but what im thinking of going with is, LMC has a dual electric fan and it comes with a wireing harness, relay, adjustable temp switch and install instructions. Truck Parts and Truck Accessories
Old Mar 8, 2013 | 12:14 PM
aksallday's Avatar
ya thats what im talking about, not too bad.
Old Mar 8, 2013 | 12:15 PM
aksallday's Avatar
should be trying to crank it over today or tomorrow, hopefully it goes well.
avonderlinde
Mar 8, 2015 04:05 AM
TORDIS713
Lowering Tech
Sep 30, 2013 10:56 PM
franklin
Nov 29, 2010 09:12 AM
scott240
Jun 14, 2010 11:41 PM
mcshirl42
Apr 26, 2010 01:34 AM
