2000 Blazer sluggish on initial take-off
Old Aug 25, 2007 | 03:58 PM
jtharp17's Avatar
jtharp17 is an unknown quantity at this point
Default 2000 Blazer sluggish on initial take-off
2000 Blazer very sluggish on initial take off. It does this in reverse and drive. It will do it after being shut off for five minutes or all day. It does not do it after it has been idling for any amount of time, only after being shut off. Just replaced catalytic converter and it continued. Check engine light still on also. Any ideas on what it could be?????
Old Aug 25, 2007 | 05:37 PM
Default RE: 2000 Blazer sluggish on initial take-off
I would start by having the codes read and let us know what they are.
After that, I would recommend a MAF sensor cleaning. Overtime, the MAF sensor can become diry and compromise it's ability to feed the proper airflow reading to the PCM. This is amplified by the use of an aftermarket oiled air filter (K&N for example). If you run a search on 'MAF cleaning', you should find the procedure, but please let us know if you have any further questions.
Old Aug 26, 2007 | 02:11 PM
jtharp17's Avatar
As a matter of fact, it does have a K&N air filter. My husband will try cleaning the MAF and maybe that will work. He is also in the process of getting the codes read.Will let you know what they are. He also replaced the spark plugs today. Thanks for yourhelp.
Klturi421
Mar 23, 2012 03:02 PM
busyflyin
Mar 11, 2012 06:31 PM
00blazerls4x4
21
Sep 5, 2011 06:46 AM
bornla
Nov 28, 2009 11:55 AM
KC96Blazer
Sep 5, 2009 05:21 PM
