2000 blazer slushy noise
Old May 9, 2012 | 06:29 PM
nore's Avatar
nore is on a distinguished road
Default 2000 blazer slushy noise
I have a 2000 blazer and when I give it gas I can hear like a slushy flowing sound,almost like if it starts from the front and runs to the back of car. Any info on what this could be?
Old May 9, 2012 | 09:06 PM
Water trapped inside the rocker panels and or doors? The drain holes might be clogged with debris. On the inboard side of the rockers, there are several black plastic body plugs, pop 'em out and see if water drains out.
Old May 10, 2012 | 12:48 AM
nore's Avatar
I will check that out but it also does it when the suv is not moving. It sounds like its coming from the center area of s
Blazer.
Old May 10, 2012 | 04:05 PM
I see, in that case, check the coolant level, most likely it's low. If in fact it's low, check for a coolant leak at the intake manifold gasket, (very common place to leak on this engine).
Old May 10, 2012 | 08:29 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
deffinately engine coolant... lift font end a bit and do a good bleed... i did and topped off gal and a half... ud be suprised.
Old May 11, 2012 | 02:34 PM
nore's Avatar
I checked it,but it's at the add point so im gonna fill it up and see what happens. I do want to thank u two for ur info. Thank you.
also some times the area around the gas pedal gets real hot,whats ur take on that ?
jlm1122
Mar 29, 2010 02:43 PM
A_&_J_Hernandez
Jan 27, 2010 11:26 PM
el8232
Nov 22, 2008 04:27 PM
Dee Dee
Apr 29, 2008 10:38 PM
ptwarrior92
Jan 31, 2007 03:01 AM
