2000 Chevy Blazer LS 4x4 Noise
Old Jan 30, 2007 | 06:06 PM
ptwarrior92's Avatar
ptwarrior92 is an unknown quantity at this point
Default 2000 Chevy Blazer LS 4x4 Noise
I own a 2000 Chevy Blazer LS 4x 4 2 door with the 4.3 V6 automatic with air. Lately in the morning when I start to drive it I hear a clicking and small grinding noise that seems to be coming from the right front tire/right front engine compartment area (also sometimes sounds like a baseball card that was stuck in the spoke of a bicycle rim). It gets louder when I drive faster and dissappers when the car comes to a complete stop. The only thing that seems to correct this is when I shift it into 4 wheel drive and then back into 2 wheel drive. I have had the car to the dealership 4 times now and they cannot seem to locate the problem (the car only has 44,000 miles on it and is still under warrenty). They have told me they have checked the brakes and abs system along with the 4 wheel drive system and all look good (although right now I am questioning that). Any ideas as to what may be causing this as right now I am at a total loss. There are no modifications made to this car, and the most recent work done to this was a new serpintine belt. Thanks for your help.
Old Jan 30, 2007 | 10:48 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: 2000 Chevy Blazer LS 4x4 Noise
Sounds to me like your front axle is not disengaging all the way. I would check the vacuum system that runs the front axle disconnect. Korey.
Old Jan 31, 2007 | 01:58 AM
BlazerMan85's Avatar
BlazerMan85 is an unknown quantity at this point
Mine does the same thing basically. It's the vacuum switch on the transfer case, available at your local Pep Boys on the shelf, $15. Motormite P/N 49315.
Old Jan 31, 2007 | 03:01 AM
Chevy Lover's Avatar
I agree with both replies. That little transfer case switch can be a problem when it sticks.
mcanter23
Sep 5, 2010 09:36 PM
Bradley2424
Mar 19, 2010 01:20 PM
crags
Nov 21, 2008 02:25 PM
crags
Nov 20, 2008 09:16 AM
COUNTRYBOY061488
Aug 28, 2008 07:54 PM
