2000 blazer sport utility upper noise and runs rough.
Well I think I have bad news. Pressure check is 60 psi and only 3 psi lose. And stays just below 60 psi cranking. So I take it it is blown. Unless some one has some other idea.
I made an add on craigslist and got an reply today:
HELLO IM GREG FROM GIAUTO PARTS I CAN GET YOU A MOTOR WITH 80,000 MILES FOR 450 DOLLARS AND THAT ALSO INCLUDES SHIPPING TO YOUR LOCATION AND HAS A 90 DAY WARRANTY IF INTERESTED LET ME KNOW OK AND TY.
GIAUTOPARTS
Does anybody hear of this guy? Sounds like a good price I believe.
Waiting for response.
GIAUTOPARTS
OK here something. I had my son change oil the other day. But I just added 1 gal. Just to flush it out and to lower the oil sense it was so much in there. It did smoothen it it out some. But did not show on dip stick. I just had him check it again, still does not show on dip stick. I know it takes 5 qts but 4 qts should show on the dip stick Yes/No?
Follow the steps in this link and it will take you to the problem: https://blazerforum.com/forum/2nd-ge...eakdown-88305/
P.S.
I did read through post five link. That is why this post is being made. Pressure last night none today.
Nowhere in the link does it mention checking pressure while cranking. All pressure readings are taken with the key on, and the engine off.
When the pump activates, you should hear the fuel rushing through the pressure regulator, which is inside the plenum.
