2000 blazer starts an dies
Old Nov 24, 2013 | 07:47 PM
big-j's Avatar
big-j is on a distinguished road
Default 2000 blazer starts an dies
my 2000 blazer starts an dies. just keeps doing that. if you hook jumper cables to it an let chargeit will start an run.sometimes you have to try it a few times.
Old Nov 24, 2013 | 07:51 PM
When you get it running, remove the jumper cables and check the voltage at the battery, (while it's still running).
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Ok,&???????????? So what your saying is if u charge the battery 1st it will run when u start it? Sounds like your culprit is a bad alternator!!! U should take it off and go have it tested at any auto parts store
Old Nov 24, 2013 | 07:56 PM
big-j's Avatar
that's what im starting to wonder. I thought of crankcase sinsor too. it cranks over real easy fires then dies. an after I mess with it long enough I have to jump it it seems to run after awhile.
Old Nov 24, 2013 | 07:58 PM
big-j's Avatar
I see the vault gauge bounce back n forth.
Old Nov 24, 2013 | 08:00 PM
What is the voltage when it's running? Could also be a Passkey problem. After it starts, is the security light on?
Silver00LT
13
Dec 8, 2012 09:11 PM
reddheadnla
Apr 23, 2011 11:08 AM
Big Ted
Nov 8, 2010 10:21 AM
blbikerood
Jan 19, 2010 06:09 PM
Blazer Will
Dec 13, 2009 06:22 PM
