2000 Blazer temp guage problem
As you can see from pic my guage is a little inaccurate. Is it fubar? Trip to bone yard and new cluster I'm guessing. I checked and the connector isn't attached to the temp sensor because the plastic top of sensor is broken. Thanks in advance.
Could be the pointer got loose on a peg and is dangling donwside. Especially if the position is permanent, on a cold engine (with ignition off) and while running.
If not - hook with a dongle and lookup the coolant temp readings.
Well checked the temp sensor and replaced it and no change. Went to boneyard got a new speedo cluster and all is well, but I'm a bit poorer though and my Bazer also gained 50k miles sitting in the garage. lol Thanks all.
I had to replace my gauge cluster too when my speedometer needle would act as if it got stuck as certain speeds and then jump up or down to the new speed. I gained about 68k miles.
After I did this I found a place on the web that refurbishes the individual gauges. Cost wise I think it would have been a wash between that and one from a boneyard.
drummerdude
11-07-2011 07:35 PM
zakm0n
01-09-2011 07:31 PM
pmezo
28
11-06-2010 04:30 PM
bertrenolds
12-19-2008 07:45 PM
myronhntr80
03-06-2008 07:58 PM
