2000 Jimmy dies at every stop!
Old Jun 30, 2012 | 06:43 AM
rtolley1's Avatar
rtolley1 is on a distinguished road
Default 2000 Jimmy dies at every stop!
Before the fuel pump went out this was a symptom,I thought, of a dying fuel pump.The pump did go out and was replaced. Only to have the same problem. It shows no codes, but dies at every stop light, sign, alley intersection. I used a MOC SYSTEMS throttle body and upper engine cleaner thru a manifold vacuum line to clean IAC and EGR. After the smoky clouds still died in the alley when I came to s stop. I'M LOST
Old Jun 30, 2012 | 08:24 AM
50lb_cat's Avatar
Have you done a fuel pressure and leakdown test? Cleaned the MAF sensor? When was the last time it had a tune up?
Old Jun 30, 2012 | 03:17 PM
step66's Avatar
Exactly...
Old Jun 30, 2012 | 03:54 PM
billfrank85's Avatar
billfrank85 is on a distinguished road
What brand pump did you use?
Old Jun 30, 2012 | 08:57 PM
rtolley1's Avatar
the pump was aftermarket. the truck was doing this before the pump went bad. not positive on the tune up, it's probably been a while, it's not my truck.no on the fuel pressure and leakdown check and maf. check that out monday. it's at my cousins shop. he's ase cert. and thought it was IAC or TCC
Old Aug 10, 2012 | 10:00 PM
rtolley1's Avatar
problem was either crankshaft sensor or fuel pump. although it was new i returned it for a swap.installed crankshaft sensor & new pump at the same time and now it runs good.
dbleobarbie
Jan 9, 2014 04:14 PM
dannyb91979
Jul 16, 2013 06:08 PM
bolthandle54
Feb 5, 2012 02:55 PM
live4liftin4848
Jan 2, 2010 10:59 PM
sjrose
Mar 21, 2009 09:15 PM
