2000 LS BLAZER 4X4 Cold Start Idle Down ProblemWill not
Old Dec 12, 2013 | 01:35 PM
RobD's Avatar
RobD is on a distinguished road
Default 2000 LS BLAZER 4X4 Cold Start Idle Down ProblemWill not
On cold startup,when outside temps are in 20s,or colder, starts and settles out at about 900rpm.Instead of warming,and continuing to idle down normally to 625-650,it stays at 900.If I turn off engine,and restart after a short period it will go ahead and idle down,on second restart.Engine temp gage still on cool side.Ive replaced idle control sensor on throttlebody,and coolant sensor on lower drivers side of engine.It seems to work fine on temps above 32 degrees. IF SOMEONE CAN HELP ME ON THIS PROBLEM,IT WOULD BE APPRECIATED!
Old Dec 17, 2013 | 09:31 PM
Double d's Avatar
Double d is on a distinguished road
thermostat maybe .. its what mine was doing , rubber o ring around the themostat was letting coolant bypass thus free flowing the coolant thus not letting the engine come up to full temp and making it idle higher
Old Dec 18, 2013 | 05:25 AM
LannyL81's Avatar
I agree with above....change-out the thermostat. Had one that stuck open and engine would never come-up to normal operating temp which caused high idle and reduced fuel mileage.
Old Dec 20, 2013 | 11:32 AM
RobD's Avatar
Thanks,Double d for your input!
Old Dec 20, 2013 | 11:34 AM
RobD's Avatar
Thanks LannyL81 for your input!
Old Dec 22, 2013 | 09:42 PM
Double d's Avatar
did that work for ya robD?
Old Jan 8, 2014 | 07:49 PM
Lazarus's Avatar
Lazarus is on a distinguished road
My blazer is doing something very similar but according to the temp guage it is running at normal temp and even sometimes goes a little higher than I am used to seeing. Could this still be the thermostat or is it maybe the temp sensor and then that is giving false reading to PCM?
Old Jan 9, 2014 | 02:07 PM
RobD's Avatar
Double d,Dont know yet? Weather been nasty,but put in new 180 about a year ago.Like I said it wont idle down at temps in the lower 20s or colder,but temp guage works fine to full operating temp and it still doesnt idle down,in these temps.I kill the engine and restart, it idles down perfectly.It takes 2 starts for some reason?
Old Jan 9, 2014 | 02:12 PM
RobD's Avatar
Lazurus,Dont know for sure,but since its running a little hotter, I would go with new thermostat.Chances are its sticking.
tate456
Feb 5, 2020 09:35 AM
Helter80
Jan 22, 2014 09:42 AM
67pacecartrust
May 5, 2010 08:47 AM
97BLAZE4X4
Feb 7, 2010 07:33 PM
proper
Jan 13, 2010 06:49 PM
