2000 s10 blazer sluggish
Old Mar 4, 2010 | 01:15 AM
robbi_carter's Avatar
robbi_carter is on a distinguished road
Default 2000 s10 blazer sluggish
ive got a 2000 blazer it starts and idles fine, but have a problem when i put my foot in it. it bogs down like its starving for fuel or air then takes off. i have put a new cat on it new plugs and a new tps, it runs fine if you put the foot in it easy but not if you go at it fast. any help would be great. thanks.
Old Mar 4, 2010 | 01:24 AM
bandidolenny's Avatar
Is there a check engine light?
Is the air filter clogged?
Is it hard to start?
Get hold of a fuel pressure guage and check the fuel pressure. You may have a weak pump that cant keep up with the engine under load.
Old Mar 4, 2010 | 07:25 AM
taba5's Avatar
taba5 is on a distinguished road
if it hasnt burned out the o2 sensors yet it could be your cat, i just went through an almost 400$ ordeal on my cat, and now gotta flip 65 for bank 1 sensor 3 o2
Old Mar 5, 2010 | 07:23 AM
no light starts fine, new air filter. just seams starvin for somethin im gonna check codes today.
Old Mar 5, 2010 | 07:34 AM
taba5's Avatar
The instance with mine may help.. A long while back I threw a o2 heater circuit code, and payed not much mind to it besides knowing which code it was, and then just cleared it till money was available. Well when I cleared it that time there was NO noise from underneath the truck... after a few months the code came back and a rattle started to appear
I cleared it again since it was the same code as before (I payed no mind to it because it didnt hurt performance or mileage)
The rattle was more pronounced as the days went by and after the 4th time of flipping the code the rattle was SO BAD that I couldnt take it anymore.. so after the "bang on it" test I decided to have it done..
IF the cat breaks up enough it might not throw a code because excessive pressure will not over heat the o2 sensor before the cat but IT WILL clog up your muffler and cause excessive pressure just enough to restrict performance.
mine had no go the day I took it to the shop, I could mash the pedal through the floor and it wouldnt get with it like normal, but the night before that it was fine, besides the rattle
Old Mar 5, 2010 | 01:42 PM
code says lean bay 2 im gonna clean maf sensor and clear code see how that works.
Old Mar 5, 2010 | 11:15 PM
Quell's Avatar
Quell is on a distinguished road
Clean egr to
Old Mar 8, 2010 | 07:18 AM
whats the difference in the fuel pump from a four door 4wdrive and the 2 door 2wdrive, with the same motor just the connections? will they interchance
Old Mar 8, 2010 | 07:38 AM
Tank depth/geometry is different. They do not interchange.
kennyking927
Aug 29, 2014 12:17 AM
rednekk
Jul 8, 2011 09:25 AM
big armo
Jun 15, 2011 01:17 AM
mechanicguy2009
Mar 27, 2010 08:42 AM
jtharp17
Aug 26, 2007 02:11 PM
