2000 timing is crzy
Old Mar 22, 2008 | 04:26 PM
rob2129us's Avatar
rob2129us is an unknown quantity at this point
Default 2000 timing is crzy
I have a 2000 s10 w engine code 4x4 blazer. I pulled the distributor and put in a used one from ebay. Now the timing os off -28'. We pulled the distributor and moved it just one tooth and then it was +28. We checked to make sure 2x that we only moved it one tooth. We had a diagnostic scanner tool on it and tried to do a case relearn but the fuel shutoof wouldn'y even keep it from reving to 6000 rpm. Could this disributor be out of a differnt 4.3 making this happen? thanks Rob
Old Mar 23, 2008 | 02:05 PM
rob2129us's Avatar
Default RE: 2000 timing is crzy
any ideas please? is there a difference if i got one out of a y code motor and not a w code plz guys any ideas??
Old Mar 23, 2008 | 02:54 PM
rriddle3's Avatar
Here is the installation procedure for your distributor. Did you follow these steps?
[IMG]local://upfiles/4800/2B17282D30334919B9CD70C018BBEF7D.gif[/IMG]
Important:The engine front cover has 2 alignment tabs and the crankshaft balancer has 2 alignment marks (spaced 90degrees apart) which are used for positioning number 1 piston at top dead center (TDC). With the piston on the compression stroke and at top dead center, the crankshaft balancer alignment mark (1) must align with the engine front cover tab (2) and the crankshaft balancer alignment mark (4) must align with the engine front cover tab (3).
Rotate the crankshaft balancer clockwise until the alignment marks on the crankshaft balancer are aligned with the tabs on the engine front cover and the number 1 piston is at top dead center of the compression stroke.
[ol][/ol][IMG]local://upfiles/4800/F380B11A0DEC433AB921BF1A5D609EE7.gif[/IMG]
Remove the distributor cap bolts and discard.
Remove the distributor cap.
[ol][/ol][IMG]local://upfiles/4800/C1CAC89509504D33B2A2B6048CFAEBA9.gif[/IMG]
Install a NEW distributor gasket onto the distributor.
[IMG]local://upfiles/4800/E0EDCACF94D743C287E5E43F0C8690DC.gif[/IMG]
Align the indent hole on the driven gear with the paint mark on the distributor housing.
Ensure that the distributor rotor segment points to the cap hold area.
[ol][/ol][IMG]local://upfiles/4800/DD6996B066FF4F1784A5C9934CB3AC2E.gif[/IMG]
Align the slotted tang in the oil pump driveshaft with the distributor driveshaft. Rotate the oil pump driveshaft with a screwdriver if necessary.
Align the flat (1) in the distributor housing toward the front of the engine.
[ol][/ol]
Old Mar 23, 2008 | 03:13 PM
rriddle3's Avatar
[IMG]local://upfiles/4800/668AB493B7514301B279BC1B95CE0EAE.gif[/IMG]
Install the distributor and distributor clamp. The flat in the distributor housing must point toward the front of the engine.
[IMG]local://upfiles/4800/F33BDF8D5B6F402491875D489AE65C66.gif[/IMG]
Once the distributor is fully seated, align the distributor rotor segment with the number 6 pointer (1) that is cast into the distributor base. If the distributor rotor segment does not come within a few degrees of the number 6 pointer (1), the gear mesh between the distributor and camshaft may be off a tooth or more. Repeat the procedure again in order to achieve proper alignment.
[IMG]local://upfiles/4800/25DC875BB7334A3EA6F4CA269574948C.gif[/IMG]
1. Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the distributor clamp bolt.
Tighten
[ol][/ol]
Tighten the distributor clamp bolt to 25N·m (18lbft).
[IMG]local://upfiles/4800/4D69C49ECA594BBB9FB7FFAFF84C9587.gif[/IMG]
Install the distributor cap and NEW distributor cap bolts.
Tighten
[ol][/ol]
Tighten the distributor cap bolts to 2.4N·m (21lbin).
[IMG]local://upfiles/4800/958DC0D892A04B208C70F0938261D043.gif[/IMG]
Install the ignition coil wire harness.
Old Mar 23, 2008 | 05:36 PM
972DRBLAZER's Avatar
972DRBLAZER is an unknown quantity at this point
nice write up rriddle3
Old Mar 23, 2008 | 06:48 PM
rob2129us's Avatar
riddle3 thanks for the very detailed help. So it looks like there is no difference in the y or w code. I am thinking we did not check the alignment marks on the bottom thnaks for the reply
Old Mar 23, 2008 | 09:06 PM
Well, a search would have yeilded much the same information without the wait...
EDI Engine timing
Doctorvette
Nov 5, 2012 11:57 PM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
determan
Jun 18, 2009 06:57 PM
