2001 2WD Computer In & Out
Old Mar 12, 2011 | 01:20 PM
Joey1986Z's Avatar
Joey1986Z is on a distinguished road
Default 2001 2WD Computer In & Out
Hello, The computer tends to 'go out' about 10% of the time. The vehicle will go into limp mode during this time with no SES light and any stored codes are deleted ( I get the occasional P0141). The other 90% of the time the vehicle runs fine. Could this be a ground issue? Wireing harness? Bad Computer?
Thanks!
Old Mar 12, 2011 | 03:42 PM
Doubtful that it's a ground or PCM issue. If there's an electrical problem with the OBDII, it will set a DTC. A loss of fuel pressure however, will not necessarily set a DTC. You'll need to have test equipment available to check it when it acts up.
Your P0141 DTC is a heater circuit issue with the bank 1 sensor 2 oxygen sensor. When the heater fails it will take longer for the PCM to switch to closed loop operation and will cost you some fuel mileage.
JohnBarJB
Sep 28, 2020 07:34 PM
rsvensson
14
Feb 9, 2014 06:01 PM
Joey1986Z
Apr 24, 2012 10:53 AM
abig84
Jan 5, 2012 08:23 PM
BLAZER97LS
Dec 5, 2011 02:25 PM
