2001 ABS light on-NOT the front hubs
Well, I've kind of put it on the back burner for the winter (probably not the best idea to have it non-functional for snow/ice..). Gonna try to get a junkyard replacement once it warms up.
Maybe I'll give the power/grounds one more going over. Every once in a while when I start up, the light will go off for a minute, but then come back on. Or I'll brake and get the 'chatter' of the ABS kicking in.
If I come up with any revelations, I'll let you know. Thanks for the hints/updates.
Well got my Actron ABS scanner today in the mail. Got a C0265 EBCM relay fail out of the history. Did some research and most of what I found says to check the ground for the EBCM. Well not sure if that is the end all for the ABS light but worth a try.
Does any on know where the ground for the EBCM is?
I also found a post saying that if you get a C0265 and C0266 then your EBCM is toast with out a doubt.
I think I read that the ground is under the air filter box attached to the radiator support.
Well, don't quote me on it. Lol
I need to check my my ground. Both my lights are on.
Any starting point is better than no starting point IMO
So true.
What part of Texas are you from? I'm in Houston.
Can't believe I missed these two threads.
https://blazerforum.com/forum/showth...ighlight=C0265
https://blazerforum.com/forum/showthread.php?t=12898&highlight=C0265
Good threads. I'm going to check my grounds this weekend. My lights aren't on when I start the truck but will come on anywhere from 10 minutes to 30 minutes.
max1995
12-06-2010 08:24 PM
damageinc98
07-12-2010 10:47 PM
stormshadow1
04-23-2009 09:46 AM
Chevyguy032
05-01-2008 11:09 AM
