Converting front hubs??
Old Dec 23, 2006 | 12:12 AM
Chevyguy032's Avatar
Chevyguy032 is an unknown quantity at this point
Default Converting front hubs??
Ok well the hubs in my blazer are starting to go so i figure i will replace them and ceonvert them to manual locking hubs..now is this a big job?? Also do I buy a conversion kit or what??and where should I get this?? I did some reserearch and couldnt find alot on this...Thankz
Old Dec 23, 2006 | 12:20 AM
20Blazer00's Avatar
Default RE: Converting front hubs??
There should be kits available from the major 4x4 supply companies. Just do a google. If you are really mechanical you could look at local recycle/wrecking yard to see if any older 4x4 large front axles have manual hubs and remove them and install them on your truck...but the best bet is the kits...
Old Dec 23, 2006 | 01:46 AM
Chevy Lover's Avatar
We have a number of 4X4 specialty shops around my area, so that's where I go.
It's not a big deal to change them over to manual hubs, I've changed to manual on my '85.
The hubs come packaged with an exploded view instruction page, I do one side at a time and I have a habit of laying all the parts out in the order that they come apart. ('cause I have a short memory)
I am very happy with my manual hubs. I service them once a year.
Old Dec 23, 2006 | 05:44 PM
20Blazer00's Avatar
Wished it could get manual hubs for this IFS setup...don't trust the vacuum/cable mechanism after reading all the problems with leaks and such failing at the wrong time...could at least make the vacuum lines a little heartier or metal...
Old Dec 23, 2006 | 06:14 PM
^ Hanr3 made a "How to" post some time ago with pics and step by step instructions on how to change your vacuum system over to a manual cable system.
Old May 1, 2008 | 11:09 AM
Rakkasan00's Avatar
Rakkasan00 is an unknown quantity at this point
Are thes kitsthe samefor the 1977 Blazer front hubs? Just was reading and thought I would ask? I am wanting to do the same.
Barney
Sep 13, 2010 06:03 AM
blrob5
Jul 4, 2010 11:14 AM
mcblaze
Oct 21, 2009 03:32 PM
Baja Blazer 85
Sep 6, 2009 07:51 PM
phantom
Aug 21, 2007 06:52 PM
