2001 blazer 4x4 hard starts
Old Apr 2, 2009 | 11:28 PM
miamiii13's Avatar
miamiii13 is on a distinguished road
Angry 2001 blazer 4x4 hard starts
I am having trouble starting my blazer especially when it is below freezing. Now that it is warm it starts very hard, almost to the point where it kills the battery before it starts. Sometimes I have to spray starting fluid to get it to start. After I get it started and it runs for a while it starts fine, until it sits for an hour or so then it has trouble starting. UPDATE as of today the truck wont start at all it trys to turn over but wont start someone mentioned today to try changing the spider could this be the problem?
Old Apr 2, 2009 | 11:31 PM
blzrls's Avatar
blzrls is an unknown quantity at this point
thinking you might get a bigger response if you post in the tech section. oh and Welcome!
Old Apr 3, 2009 | 12:01 AM
miamiii13's Avatar
Default tech forum
where and how do i do that. I had hard enough time posting this here.
Old Apr 3, 2009 | 08:42 AM
Welcome. I have responded to the other thread you replied to, but I will move this thread into the 2nd Gen Tech section for your discussion.
That hose that is on the passenger side of the radiator fan shroud is for the AIR pump. It is supposed to be like that.
Have you tested fuel pressure?
Old Apr 3, 2009 | 08:46 AM
oisinirish's Avatar
Welcome.
Old Apr 3, 2009 | 11:12 AM
Smoked's Avatar
Smoked is an unknown quantity at this point
Hey...i have a similar problem. Do you have a block heater? If so, plug it in on a cold night and see if it starts any easier in the morning. My problem seems to be sticking poppet nozzels on the spider injector unit. If i plug it in, starts first try every time. Starter fluid also works. From 9 degrees to -15 it is sluggish to start on it's, and below -16 it needs to be plugged in....and this is AFTER running a can of Seafoam through the fuel system once a month in the winter.
Old Apr 3, 2009 | 04:22 PM
You need to check fuel pressure and leakdown also. You'll find a problem. https://blazerforum.com/forum/showthread.php?t=23038
Old Apr 12, 2009 | 10:45 PM
rsturge's Avatar
rsturge is an unknown quantity at this point
I think the both of you might have a fuel pump problem
Old Apr 13, 2009 | 04:56 PM
miamiii13's Avatar
Default spider
I did change the spider along with the plugs and the problem is solved. So i thought. the day after it would not start til i sprayed starting fluid in the throttle body then hasn't acted up since, who knows.
cavired99
May 12, 2014 10:27 PM
CountryRed
Jul 22, 2011 05:47 PM
richy97blazer
Nov 11, 2010 04:55 PM
dalifts
Jan 25, 2009 07:13 PM
alan98296
May 8, 2007 01:06 PM
