2001 Blazer Door Lock
Old Mar 11, 2010 | 01:55 PM
Redlegger's Avatar
Redlegger is on a distinguished road
Default 2001 Blazer Door Lock
My son has a 2001 Blazer. I drove it today and noticed his electric doorlock is not funtioniong. It clicks but nothing happens. No other problems that I can see. Is this a fuse ? relay ? Any help would be appreciated. Thanks
Old Mar 13, 2010 | 10:43 PM
jjnemoiii's Avatar
jjnemoiii is on a distinguished road
Is just a problem with the passenger doors? Does it work fine for the liftgate? Are you refering to the switch in the door, or the remote?
Old Mar 14, 2010 | 10:46 AM
Redlegger's Avatar
It doesn't have a remote. The issue is something shorting and causing the fuse to blow. I replaced the 15 amp fuse and after about 10 tries with the lock functioning it blew. I put a 20 amp fuse in and it seemed to hold. I'm thinking since it isn't under constant power I'm probably okay with a 20 amp fuse as long as it doesn't blow. Where to look for the short ? When the fuse is blown none of the doors unlock.
Old Mar 14, 2010 | 02:43 PM
jjnemoiii's Avatar
Yes, when the fuse blows, the system should get no power, and thus not work. What size (amps) fuse is supposed to be in there? Using too big a fuse presents a fire hazard... I'm not sure, but it sounds like you have a loose wire somewhere.
hlaverty06
Mar 23, 2014 09:25 AM
tony991
Feb 17, 2014 08:01 AM
xderkax
Feb 13, 2010 06:21 PM
katsmeow
Jul 13, 2009 08:31 AM
rossg
May 27, 2009 07:48 AM
