2001 Blazer-fixed backup lights, now won't start
Old Jan 19, 2008 | 10:33 AM
luvarcadia's Avatar
luvarcadia is an unknown quantity at this point
Default 2001 Blazer-fixed backup lights, now won't start
Does anyone know, if you fool with wiring in back of 2001 chevy blazer to fix back-up lights..is the wiring connected somehow to starting the car. Fixed the backup lights and now car will not start. Can start it by putting ether in but it dies. Replaced fuel-pump thinking that was it...but no luck..Desperate..stuck out of town...thanks in advance for help!
Old Jan 19, 2008 | 10:46 AM
Sorell's Avatar
Sorell is an unknown quantity at this point
Default RE: 2001 Blazer-fixed backup lights, now won't start
You may have shorted something out when playing with the wiring, which, in my experience, can effect anything in a vehicle. I'd double check the wiring and all that.Check all your fuses and stuff too; I hate wiring so I don't play around with too much of it, but good luck
Old Jan 19, 2008 | 11:07 AM
luvarcadia's Avatar
thx...stuck in boston, live in orlando...i don't know if u read it again but i forgot to add that we replaced the fuel pump thinking it could go and we couldn't get a could spark...but did not work. so that why wondering if somehow wiring from back is connected to front.
Old Jan 19, 2008 | 01:51 PM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
All the wiring originates in the front, and some of it goes to the back. I have no idea why the backup lites, and the fuel pump would be related though.... best bet is to first, check the fuses, and see if anything is blown.
Old Jan 19, 2008 | 07:29 PM
Sorell's Avatar
Oh, well it would probablybe something morethana problem with your reverse lights.Does it crank, is there absolutely no power, power but no crank?Moredetails would help narrow down where the problem is coming from. I'd start with checking your vacuum lines first though, then all the small things like fuel pressure, check for a spark, all that good stuff.
Good Luck!
Old Jan 20, 2008 | 04:55 AM
Chevy Lover's Avatar
What did you do to fix the lights? Have you checked the fuel pump fuse and do you hear the fuel pump or fuel pump relay.
The fuel pump wiring is grounded in the body harness to right taillamp harness, at the RR of the vehicle. Is that where you were repairing your back up lights?
McGyver
Mar 8, 2015 05:37 PM
kccowman
Dec 7, 2009 08:50 AM
Shamrock3
Jun 18, 2009 06:22 PM
flyinbrad
Jul 6, 2007 07:05 PM
Shamrock3
May 30, 2007 01:58 PM
