2001 Blazer Fuel Pump Issues
Old Dec 1, 2011 | 07:52 PM
You were probably on the return line, (5/16"). The pressure line is 3/8". If you connect directly to the fuel filter, max pump output should be somewhere between 73psi and 108psi when the pump is running. After it shuts off, pressure should immediately drop, but it must remain above 55psi.
Old Dec 1, 2011 | 09:41 PM
Colten's Avatar
Colten is on a distinguished road
I did hook the gauge to the filter. This was the largest line and I also assumed it was the supply line as it is the largest and had the filter on it. So not getting any sort of pressure was confusing.
Old Dec 1, 2011 | 09:55 PM
xgiovannix12's Avatar
the line where the filter is is the line where the fuel comes from
if you didnt have any pressure its possible your pump didnt kick on
Old Dec 1, 2011 | 09:56 PM
Here's the set up I made, it connects inline to the fuel filter. With the valve open, fuel flows unrestricted.
With the valve closed you can test max pump output pressure and check for leakdown in the module:
Old Dec 2, 2011 | 03:48 PM
Colten's Avatar
Pretty sure its the check valve. So my question is, if the truck starts/runs fine at all speeds and gets normal gas mileage for a blazer (21-22mpg ) what is the benefit to replacing the pump just for the check valve?
By starts *fine* I mean if I let the pump prime for its 2 seconds and then turn the ignition it fires up first crank...if not its 6-8 cranks.
BouncingRadical
14
Nov 27, 2015 12:30 AM
hondacharger
20
Jan 14, 2012 08:53 PM
cide
Nov 7, 2009 01:26 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
