2001 Blazer lifter adjustment
Do you have that "lifter clatter" too? I've had that from day 1 & have heard the 4.3 vortecs are known for it.
Thanks for the info. going out to the garage to set them right now. Ya, I had noisy lifters the intake gasket was bad, I am replacing head gaskets, lifters and intake gaskets. Found anti-freeze in number 1 and 5 cylinder. I just replaced the intake gaskets and had the same lifter noise as before, thats why I am doing all the rest to eliminate the top end, the cam checked out ok. Also I plan on keeping the truck for awhile.
Update on my Blazer, finished up with all the work late last night and the truck runs great no more lifter noise, I did get an air pocket in the system during refilling of the rad. but worked it out the truck runs great, thanks to all for the help.
I use Sea Foam in my crank and made the lifters go quiet for awhile, now the nosie is back, I say, crap its been this way for 100K and nothing has blown. So I will leave it alone. Plus I all of a sudden develope leaks after putting the sea foam in. Its about time to change the oil. Hopefully some of leaks will stop.
NOs
09-01-2016 12:09 PM
michigan_engineering
06-10-2009 01:06 PM
spld2
11-04-2008 10:03 AM
glenmoore670
02-15-2006 11:08 PM
