2001 S-10 4.3L Wont Start
Old Apr 6, 2011 | 07:53 PM
robwatt65's Avatar
robwatt65 is on a distinguished road
Default 2001 S-10 4.3L Wont Start
Code says “random or multiple misfire” Got 55psi fuel pressure at the shredder valve, got spark at coil! any ideas?
Old Apr 6, 2011 | 08:03 PM
You can start here:
P030x - Random/Multiple Cylinder Misfire Detected
Does the pressure bleed off at all after the pump shuts off?
When was the last time a tune up was performed? Plugs, wires, cap & rotor?
Old Apr 6, 2011 | 08:29 PM
Jim94blazer's Avatar
Jim94blazer is on a distinguished road
Default 1994 vortex 4.3 blazer wont start
I think it is the fuel pump, good spark at coil and plugs and with key on no pressure at shrader at all and no noise at fuel tank. Sound like a lot of people chasing something. How hard is it to change pump in tank?
Old Apr 7, 2011 | 11:59 PM
I replaced the pump in the tank, not to bad 6 hours had to stop and get a get 18mm inpack socket, Autozone, had pump for 76$ and the pump and screen and sending unit for 96$ shucks said same part number with out sender 96$ with sender 216.00 same part the said Autozone has it wrong, I bought it from Autozone and paid 96$ for it all. Didn't know the pump is cooled by the gas and driving around on 1/8 a tank will over heat the pump. Good info. It was the Airtex, brand I will let you know how long it last. Thanks for all the info.
hondacharger
Jun 14, 2010 01:47 PM
ejy1
Apr 14, 2010 07:26 AM
blzrDan
Mar 31, 2008 09:21 PM
redpeppers
Sep 11, 2007 01:07 PM
ChevyNewb
Aug 3, 2007 04:13 PM
