2001, sputtering, backfiring doesnt want to go
Old Aug 6, 2010 | 10:13 AM
gagirl320's Avatar
gagirl320 is on a distinguished road
Default 2001, sputtering, backfiring doesnt want to go
Ok, yesterday on my way home my blazer started to bog down, it wouldnt go when I pressed the gas, when I put the truck in park and pressed the gas it would rev fine, then once I put it in drive it wouldnt go over 30MPH and it would back fire.
We thought it was the fuel filter, changed that, still sputtering.
Any thoughts? Open to suggestions.
Thanks
Old Aug 6, 2010 | 06:33 PM
Sounds suspiciously like a catalytic converter failure. If you hit the catalytic converter with a rubber mallet, does it sound like stuff is rattling around inside?
Old Aug 6, 2010 | 11:59 PM
nitetrane98's Avatar
nitetrane98 is on a distinguished road
I recently bought a '95 Blazer that was in excellent shape but had a serious backfiring problem. To the extent it had made the oval shaped muffler into a big round muffler with the inlet end blown open. The previous owner claimed to have put new tune up components, plugs, wires, filters, etc. in and from the looks of everything he had. I noticed that it ran semi- OK when it was cold or at steady highway speed. In town, after it had warmed up, it would barely run. That reminded of a problem on another car that exhibited the same symptoms. I replaced the ignition control module and it fixed the problem. Judging solely from looks it was very likely to have been the original.
This may not fit all of your symptoms but the backfiring can be caused by the cylinder getting a shot of gas and not getting fired on and passing the rich mixture into the exhaust where it eventually finds an ignition source.
Old Aug 7, 2010 | 10:10 AM
R2P's Avatar
R2P
R2P is on a distinguished road
This does sound a lot like when my cat converter substrate broke up and clogged my exhaust. I didn't have backfiring though.
In park the engine would seem fine and rev appropriately but in drive up to a certain throttle position it would have almost no power and going WOT resulted in the engine revving up high but no acceleration, almost like the torque converter had failed.
Replaced the cat and minus a few bits of catalyst substrate still in the muffler, it runs great.
Also, when I was driving it with the cat clogged like that a hummer probably had better mileage than I did. Figure a quarter tank of gas or more for a drive across town and back ~25mi total.
grwarren
Jun 20, 2013 12:47 PM
pfunknasty
Apr 23, 2012 10:36 AM
mobcittty
May 17, 2011 03:53 PM
ExplicitYourSelf
Jun 16, 2009 06:35 PM
in4lo
Dec 7, 2008 08:55 PM
