2001 W Engine fuel pressure regulator
Old Feb 7, 2006 | 01:59 AM
jr9880's Avatar
jr9880 is an unknown quantity at this point
Default 2001 W Engine fuel pressure regulator
Hello,
I have an 01 4x4 4 door blazer w/ a W engine. I have replaced all 6 injectors, spark plugs and temperature sensor in the head. My problem is extended cranking followed by a pure fuel smell when the vehicle finally starts. A mechanic told me it could be the fuel pressure reguulator. The vehicle is not throwing any codes-mechanic just put it on the scanner. Vehicle has correct fuel pressure. If the vehicle sits for a while, then it will start fine. My question is this: where is this fuel pressure regulator located and does anyone have any clues to what is going on with my vehicle?
Thanks[:@]
Old Feb 8, 2006 | 07:08 AM
Default RE: 2001 W Engine fuel pressure regulator
I suppose it is possible that the FPR is the culprit... More to your question, the FPR is located on the back fuel injection spider under plastic upper intake plenum.
My question is this, who replaced the injectors? A 2001 has the CSFI unit which has 6 individual injectors in a central housing. From each injector, a tube runs down to a poppet injector in the intake ports pointing at the intake valves for each of the respective cylinders. The reason why I state all of this information is because it is FAR cheaper to replace the entire CSFI spyder (6 injectors, the spider body, and the FPR) than it is to replace all 6 individual injectors. Heck, it's cheaper to upgrade to the SMPI system used in the '04+ 4.3Ls which put the injectors down in the intake ports where the clog-prone poppet valves are in your current fuel injection setup. The later SMPI system is a direct replacement in the earlier CSFI systems.
swartlkk
39
Feb 20, 2010 09:39 PM
dyeraudio
Dec 30, 2008 02:43 PM
Memphis64
Nov 21, 2008 10:07 AM
jlinder
Aug 21, 2005 11:08 AM
