2002 2wd Blazer
Old May 22, 2010 | 09:57 AM
venom01's Avatar
venom01 is on a distinguished road
Angry 2002 2wd Blazer
I have replaced the front and rear breaks and rotors and I am still getting a squeeking noise when I begin to move forward. The noise tapers of at about 25mph but never goes away. I am thinking it may be the U joints ( but do not understand why no noise when in reverse or when on jackstands) I could really use some help
Old May 22, 2010 | 12:01 PM
How much clearance is there between the clips on the rear caliper brackets and the rear rotor?
Old May 22, 2010 | 02:08 PM
twistedsmily's Avatar
twistedsmily is on a distinguished road
what about wheel bearings. Just a thought.
Old May 22, 2010 | 09:58 PM
R134A's Avatar
R134A is on a distinguished road
Had same problem you are right change your U-joints.
Front and rear.
Last edited by swartlkk; May 23, 2010 at 01:09 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 22, 2010 | 11:19 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
X2, check the anti-rattle clips on the caliper brackets and try greasing up the u-joints ( that is if you have a grease fitting on them)
Old May 23, 2010 | 11:53 AM
venom01's Avatar
The pasenger side was just changed last year but not the drivers side.
Looks like it is going to be a drag. I have to go get a torch, as I have heard getting the front u joint out will take quite a bit of heat and strength.
Not sure but to add zest to the issue, yesterday I was driveing it again and now I have a slaping sound comming from the front end. It sounds like one of the calipers is slaping around. I threw it up on the jackstands again today but have not been able to figure it out yet. But for now I am going to stick with the drivshaft for today.
Last edited by rriddle3; May 23, 2010 at 12:22 PM. Reason: COMBINING CONSECUTIVE THREADS
Old May 24, 2010 | 09:41 AM
venom01's Avatar
Well I just finished up this morning. I ended up cutting the base of the old u-joints out with a die grinder, leaveing only the caps in the driveshaft. Then I just heat them up with some map gas and they popped right out with a socket and a 3 lb sledge. I saw the cap that was fried. I still do not understand how the u-joint make such a weird squeek, but hey, the squeeking is gone and now I can start figureing out why one of my calipers is slapping around. lol
02Goldie_Loks
Tires and Wheels
Aug 11, 2015 06:49 PM
02Goldie_Loks
Tires and Wheels
Aug 8, 2015 01:32 AM
Bono4783
Feb 4, 2014 10:47 AM
mr_dbc
Sep 16, 2009 01:17 PM
Jorgen
Nov 6, 2007 03:06 PM
