2002 Blazer 4.3 Runs rough simple fix
Old May 2, 2010 | 10:24 AM
jeffkoski's Avatar
jeffkoski is on a distinguished road
Default 2002 Blazer 4.3 Runs rough simple fix
2002 blazer 4.3 idles rough 500rpm. runs smooth till you hit 50 - 55 mph it shifts hard when you give it more gas. Pulling up DTC codes for mass air sensor, crank sensor, cam sensor, knock sensor checked plugs autolite gapped at 75 Replaced plugs did a water test on plug wires -passed still ran rough at same speeds still pulling same codes! Solution pulled crank sensor cleaned, disconnected battery ground cleaned cleaned Mass Air Sensor with CRC, Cleaned Throttle Body Both of these were dirty . Test drive idles at 750 smooth no more miss fires climbing hills cruises at 80mph with plenty of peddle left. No more codes pulling up Sure glad i didnt replace any sensors i hope this helps somebody i guess you need to find why the codes are pulling up such a simple solution!
Old May 2, 2010 | 10:49 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Why exactly did you gap the plugs a .075? .060 is the spec they should be at.
Old May 2, 2010 | 03:23 PM
Sounds like the cleaning of the sensors/throttle body are what ultimately fixed it.
Old May 21, 2010 | 01:34 PM
redmanj79's Avatar
redmanj79 is on a distinguished road
Thanks for the info, I also have a rough Idle at 500rpm too. The throttle body was full of gunk, cleaned it up and things are a little better. Still stuttering a little, going to give cleaning the crankshaft sensor a try. Its pretty badly gunked itself from an oil leak i can't seem to locate. Almost looks like the lines from the oil filter are leaking... Has a little stutter between 1600 and 1900 rpms too. Is cleaning the MAF sensor as easy as buying some crc and spraying it down?? I know where it is but I have never removed the sensor, not quite sure what it looks like on the inside.
Old May 21, 2010 | 08:57 PM
R134A's Avatar
R134A is on a distinguished road
Glad you got your truck fixed. You did not have to do a crankshaft relearn after you cleaned the crank sensor? F.Y.I Keep in mind for the future that all those sensors have one thing in common which is vref and buy you unplugging and cleaning things you might have fixed a wire that is not making a good connection,to set all of them codes because they are dirty is very unlikely, I am not trying to burst your bubble this is just some info in case it happens again.
r_marczak_83
17
Mar 9, 2013 10:33 AM
adaptechsolution
Apr 7, 2012 12:03 PM
c10jm
Aug 12, 2008 05:34 PM
pinktruck
Aug 10, 2007 08:52 AM
Dodge Guy
Oct 25, 2006 08:48 AM
