2002 blazer no 4wd light and trans not shifting
Old Sep 25, 2018 | 02:45 PM
Jcraig's Avatar
Jcraig is on a distinguished road
Default 2002 blazer no 4wd light and trans not shifting
I have a 2002 blazer with the 4 button 4wd buttons it drove fine cut engine off then when refired and drove it would not shift and it feels like it is stuck in 4lo and no lights are on at the 4wd switch and 4wd service light is on I scanned the ecm and found an o2 sensor and mass air flow is showing bad but it is not drivable due to trans isn't shifting and all any help would be greatly appreciated thank uou in advance
Old Sep 25, 2018 | 02:49 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Have you checked both fuse blocks for a blown fuse?
Old Sep 25, 2018 | 03:26 PM
Jcraig's Avatar
All fuses have been checked and are good
Old Sep 25, 2018 | 06:42 PM
Aeromaster's Avatar
Aeromaster is on a distinguished road
Check wiring harness between PCM and trans. It runs behind the engine and can be damaged if the tranny had been remove, engine movement etc. Bare wires etc. will play haveck with tranny and 4x4.
Been there
Old Sep 25, 2018 | 10:23 PM
Jcraig's Avatar
I do know the motor mounts are going bad so I will have to check that thanks
Old Sep 26, 2018 | 06:17 AM
Strangerock's Avatar
Strangerock is on a distinguished road
The service 4x4 codes need a bit better than a standard obd reader to access them , a good reader and a good service manual could help point you in the right direction.
Old Sep 26, 2018 | 11:24 AM
LesMyer's Avatar
Check CLSTR Fuse11 in I/P fuseblock and for power at transmission connector on pink wire.
Sam74
Sep 30, 2018 07:07 PM
Tonytee71
Jul 2, 2018 12:04 AM
Charder
35
Aug 3, 2013 06:12 PM
champ186dc
Jan 9, 2010 10:34 AM
ncmudblazer
Jun 29, 2008 01:57 PM
