2002 blazer stalling and no power to engine
Old Aug 12, 2019 | 12:42 AM
curmit's Avatar
curmit is on a distinguished road
Exclamation 2002 blazer stalling and no power to engine
HI,
I have a 2002 blazer with the 4.3 it stalled today and there was no power to the engine?
Tow it home and it started up with a jump! If i hit the brakes the dash lights faker and it whats to stall out?
Could someone please help me finger this out!
Thank you for you time.
Old Aug 12, 2019 | 10:22 AM
GeorgeLG's Avatar
What do you mean no power to the engine?
If you started it with a jump then I presume that your battery was dead? What is the voltage at rest and when the truck is running?
What happens to the dash lights when you hit the brakes? Does the same thing happen when you turn on the headlights?
Have the battery or alternator been replaced?
George
Old Aug 12, 2019 | 03:58 PM
curmit's Avatar
Red face 2002 blazer stalling and no power to engine
HI,
Battery is new! Drove it 15 miles was charging battery all the way when it stall out no power to restart ?
Battery at the stall out was still charged up, but could not get the starter or lights to work no power with the key on!
Unhook the battery before tow, after towed home had to jump battery! If i hit the brakes the dash lights faker and it whats to stall out?
Old Aug 12, 2019 | 04:05 PM
LannyL81's Avatar
Sounds like the alternator is not working; is the belt on the alternator? Do you have a voltmeter? Need to put voltmeter across battery terminals when engine is running to measure alternator output voltage; voltage should be 13.6 to 14.3 Vdc or so, if less, then engine is running off of battery, which drains the battery in a short time.
If it is the alternator, good news is that they are easy to change-out.
Old Aug 12, 2019 | 04:36 PM
curmit's Avatar
alternator output voltage is 14.3, headlight also faker when on!
Old Aug 12, 2019 | 07:21 PM
GeorgeLG's Avatar
Please provide the voltages that I asked for.
Why did you need a new battery?
George
Old Aug 12, 2019 | 07:33 PM
curmit's Avatar
Battery is one year old!
Alternator output voltage is at 14.3!
wookard
Apr 19, 2013 06:14 PM
mrspeedy69
Aug 27, 2012 08:13 PM
Melrock83
Mar 12, 2012 07:26 PM
Blazin_up_high
Feb 17, 2009 09:19 PM
flowmasta
Aug 1, 2006 01:42 AM
