Battery help
Old Feb 16, 2009 | 04:44 PM
Blazin_up_high's Avatar
Blazin_up_high is an unknown quantity at this point
Default Battery help
I have a 1997 blazer, and am running a power acoustik 820 watt amp to a single kicker 12"...the car hardly turns the lights on when i start it and when the bass hits my lights go rave style on me...whats a good battery that can support the electronics? thanks
Old Feb 17, 2009 | 07:39 AM
jagblazer01's Avatar
Default RE: Battery help
kinetik or powermaster. Are you looking to add a second battery or replace your starting battery?
Old Feb 17, 2009 | 08:00 PM
blazinloud's Avatar
www.onlinecarstereo.com now carries kinetic!!!!
Old Feb 17, 2009 | 08:30 PM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
Is this while the engine is on or off? If it's when the engine is on, you should first look into upgrading your battery (-) to chassis, battery (-) to engine block, and alternator to battery (+). If that doesn't give the desired effect, upgrade your alternator.
Old Feb 17, 2009 | 09:16 PM
i was looking into kinetic or optimum, and im just looking to replace it...thanks for the advice
Old Feb 17, 2009 | 09:19 PM
what kind of kinetic battery would you recommend?thanks blazin loud and budracing its when the car is on
1998mom
Jul 25, 2013 09:43 AM
TigaHotty85
Jun 17, 2013 03:10 PM
chevyman93
Dec 17, 2012 05:59 PM
tnw912
Jan 5, 2010 05:27 PM
BradN10
Jul 22, 2006 10:58 PM
