2002 New fuel pump will not work??????
Old Aug 19, 2011 | 05:22 AM
  #21
blanco36's Avatar
blanco36 is on a distinguished road
Originally Posted by kristoph30
Are you sure something isnt killing the battery?
That I am not sure...
Old Aug 20, 2011 | 12:21 PM
  #22
blanco36's Avatar
Originally Posted by swartlkk
You can hook the ground strap of the test light up to a known good +12V source & then probe your grounds. It should light up just like it did with the clamp on a known good ground.
If you have both power & ground to the pump, then that just leaves the pump.
Bought a multimeter, it does not look like I am getting any reading for the ground???
What now?
Old Aug 20, 2011 | 05:11 PM
  #23
blanco36's Avatar
If you have +12V to the gray wire & a good ground to both the black wires and the pump still doesn't run, then the pump is the faulty component.
Hope I did this right, I put the negative part of the multimeter on the purple wire of the fuel pump connector, I checked the wht/blk ground on the plug and it read around 5 volts..... the all blk wire did not read.....
Now, will the gry power wire just read for the 3 or 4 seconds after the key is turned on? Or would that be constant? IF it is supposed to be constant, I am not getting a read on it.....
what to do now????
Old Aug 20, 2011 | 06:00 PM
  #24
blanco36's Avatar
Ok... tried again, checked the gry wire when the key is turned, 12volts
Blk/Wht wire= 12 volts
Black wire= 5 volts
Purple wire= 5 volts
Sorry for posting back to back.....
What to do now????????????????????????
Old Aug 21, 2011 | 02:08 PM
  #25
blanco36's Avatar
Ended up changing the wiring harness, and it runs now.......
Thanks everyone for your help on this issue........
BouncingRadical
14
Nov 27, 2015 12:30 AM
exorotika
Apr 22, 2012 04:18 PM
hantayo13
Jan 12, 2008 12:34 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
