2002 whining help
Old Jan 8, 2019 | 10:04 AM
Johnnn's Avatar
Johnnn is on a distinguished road
Default 2002 whining help
My 2002 blazer makes a whistle noise from front end I can't pin point what it is if I take off belt it stops I've changed a.c. compressor alternator tensioner pulley pretty much but power steering pump I cut figure out what it is I have no signs of bad power steering pump no other sounds
Old Jan 8, 2019 | 04:45 PM
GreenBlazer2002's Avatar
Did you change the belt itself? Also, it could be the water pump. You didn't mention that you changed it.
Old Jan 8, 2019 | 07:32 PM
Mike.308's Avatar
Grab the pulley, slide off the serpentine belt. Check if there's anything loose, one by one. Inspect the inner shroud space. Check if the fan mount is not broken (a metal plate where the bolts come in).
1965Chevy
Feb 14, 2015 12:32 PM
wisowebs
27
Aug 7, 2011 09:55 AM
iloveblazers
18
Oct 10, 2010 10:06 AM
leeclark
Jan 10, 2010 09:28 PM
xtr1c0
May 11, 2009 10:00 PM
