2002 ZR2 looking for fuel pump
Old Sep 17, 2017 | 03:58 AM
Garrett78's Avatar
Garrett78 is on a distinguished road
Default 2002 ZR2 looking for fuel pump
I am looking for advice on a decent fuel pump for my blazer I have gone through 2 in the past 2 weeks now I am under the impression that it is the pumps that are bad they are not built to deal with the ethanol that is in the fuel now.i have put in a spectre and a delphi and neither has preformed for very long and yes the pressure was at passing on both fuel line and bleed down just looking for a brand name that has been changed and worked also are there any high performance after markets available out there?
Old Sep 17, 2017 | 09:35 AM
Vahomboy's Avatar
Vahomboy is on a distinguished road
What brand did you install that failed? Everyone here will say to install the OEM fuel pump...AC Delco/Delphi. Yeah it costs more but I guess that depends on how often you want to change it.
Old Sep 17, 2017 | 11:28 AM
Garrett78's Avatar
The second one was a Delphi first one was a spectra
Old Sep 18, 2017 | 11:17 AM
GeorgeLG's Avatar
I am at 100,000 miles plus (replaced at 100,000) on a Delphi and still going strong.
George
Old Sep 19, 2017 | 11:49 AM
Vahomboy's Avatar
Wow! Don't know what to say to that one except for a run of bad luck. I got my oem from AA and never had no more trouble. I feel for ya because my 02 ZR2 Blazer was a b!tch!
Old Sep 20, 2017 | 02:06 PM
Garrett78's Avatar
I've turned this one over to a Chevy dealership whatever is going on is beyond my backyard mechanics abilities they should have an answer for me something else must be going on here
Old Sep 24, 2017 | 01:30 PM
jimspahr@msn.com's Avatar
As stated, everyone here recommends either an AC Delco or Delphi pump. I also read you should replace the entire assembly at the same time: pump, fuel tank level arm, and wiring harness. Some say the harness wiring gauge is too small and causes fuel pump problems. Also be sure that the fuel pump ground is good!
Old Sep 24, 2017 | 09:32 PM
Garrett78's Avatar
it was a full replacement pump with a new wiring harness Chevy got back to me it's the fuel pressure regulator and a couple of parts for the fuel injector assembly
TheSaint
May 22, 2017 09:36 AM
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
