2003 #1 cylinder help!!!
Old 09-07-2010 | 02:35 PM
jmoller's Avatar
jmoller is on a distinguished road
ok i got 60 psi reading for a second then it just drops fast. the book says it supposed to hold the pressure around 60..do u kno what that meens?
Old 09-07-2010 | 05:40 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
if your fuel pressure is droping then you have a leak. it could be the check ball in the pump or a injector or a fuel line. if you have a misfire in the motor i waould assume a injector.
Old 09-07-2010 | 07:44 PM
If you have checked for spark on #1 and verified that it is timed properly, then it sounds like your problem is a failed injector on the #1 cylinder either that or a grounded trigger wire somewhere between the PCM and the connector on the spider. You could confirm this by removing the upper plenum and reinstalling the fuel lines. Pull each injector and pressurize the system. None of them should leak. If the #1 injector leaks without the electrical connector being connected to the spider, then the injector is stuck open and needs to be replaced.
mbar
11-10-2010 02:39 PM
MetalMan390
06-08-2010 02:27 PM
jmatt07
12-18-2009 09:48 AM
Ugly_Monkey
11-09-2009 08:43 PM
97ssblazer
09-02-2009 01:08 AM
Quick Reply: 2003 #1 cylinder help!!!
