Wheel cylinder HELP!!!
Old Nov 9, 2009 | 06:04 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Default Wheel cylinder HELP!!!
So I have narrowed down my problems to a bad rear passenger wheel cylindar!
Can anyone give me any advice before i attempt to change this part?
Old Nov 9, 2009 | 07:08 PM
terry s's Avatar
terry s is on a distinguished road
First see if the fitting where the brake line connects to the wheel cylinder will turn without turning the brake line. Sometimes the nut is rusted to the brake line so when you unscrew the nut it twists the brake line. If so you will need to get a new brake line to replace it with. Don't let the master cylinder run out of fluid while you are working as fluid will come out when you have the line disconnected.
Old Nov 9, 2009 | 08:43 PM
Spray it with penetrating oil a few times a day for a few days before you attempt to break it loose.
Blazin It Down
Jul 29, 2015 01:09 PM
keyonn
Jan 17, 2014 09:32 PM
wookard
Sep 15, 2013 05:57 AM
Chic_Bowdrie
Jun 7, 2012 08:15 PM
mbar
Nov 10, 2010 02:39 PM
