2003 Blazer Repairs
Old May 14, 2009 | 01:35 PM
dacop's Avatar
dacop is an unknown quantity at this point
Default 2003 Blazer Repairs
I have a 2003 v6 Blazer with the following problems:
Engine light on - Blinking at times (misfire on cyl 3)
Rough start and turnover
Strong Exhaust smell (not normal)
Idols very rough/shakes
Accelerates roughly
Not responsive sometimes when highway diving and given gas
I took it in to a Chevy Dealer Service Dept, here is their diagnoses and work order:
Fuel Regulator is faulty and 1 Injector is leaking
Parts:
Spark Plugs - 6
Fuel Regulator
Bank 1 02 Sensor
Replaced one Bad Fuel Injector
Full Fuel Injector Cleaning
All Related Seal Kits
Faulty Cat Converter - Replaced under warrantee
Nut Muffl - Replaced under warrantee
Pipe - Replaced under warrantee
Gasket - Replaced under warrantee
Seal - Replaced under warrantee
I now have the truck back and it is running great.
My question is, what should I have paid for this?
Old May 14, 2009 | 02:25 PM
You likely paid dearly... I am not one to succumb to dealer repairs, but the exhaust I would have had them do if it was under warranty.
I would have replaced the entire spider which was likely cheaper than them replacing one injector, the FPR, and doing an injector cleaning considering both labor and parts.
I purchased the new MFI spider (PN 12568332) which included 6 new injectors, a new metering body, all applicable o-rings/seals, and a new FPR for $220 from my local dealer. You can expect to pay anywhere from $200 to the $300 MSRP shown on GMPartsDirect.com (which lists it at $170 +s&h).
The spark plugs and O2 sensor were likely double the going rate for AC Delco products from elsewhere (RockAuto.com, etc).
And I could only imagine what the shop rates would be when you stack up all of the various repairs.
bkw
May 13, 2010 02:59 PM
Selwen
Apr 5, 2010 07:58 PM
BonestockZR2
Nov 2, 2009 07:00 PM
wienerdog
Dec 2, 2008 05:56 PM
returnofsid
13
Jun 3, 2008 01:21 PM
